Environment Layer issue
Hannah Sander
on Nov 19, 2014 at 11:21:23 pm
Hello,
I'm attempting to make an Environment Layer for the first time after watching some tutorials.
However, when I right click and select "Environment Layer" my layer completely disappears.
I have the layer (and mode) set to 3D, and I have "Ray-traced 3D" rendering enabled. I'm following the tutorials verbatim, so I literally have no idea what's going on.
Any ideas?
Dave LaRonde
Re: Environment Layer issue
on Nov 19, 2014 at 11:27:26 pm
What's the Version of AE? If you're on the cloud, don't use ray-tracing. Adobe's given it up as a bad job. Use C4D.
Dave LaRonde
Promotion Producer
Hannah Sander
on Nov 19, 2014 at 11:31:42 pm
Thanks for the reply!
I'm using CS6. Most of the tutorials I followed were for CS6 as well.
Brian Charles
on Nov 20, 2014 at 10:59:11 am
You need to add a camera for the environment layer to work.
See the attached file.
8205_enviro.aep.zip
While its true that Adobe have abandoned further development of RayTracing in After Effects, I don't agree with Dave's characterization of the RayTraced renderer, I still used RayTraced 3D for some work.
However, C4D is far more capable.
Hannah Sander
on Nov 21, 2014 at 5:07:46 pm
Thank you so much for the example, Brian! I was able to open it up and have all the layers work perfectly.
However, when I opened a new composition and mimicked exactly what your layers were, my environment layer still disappeared! Is there a specific order I need to do it in?
I made my solid layer with a fractal noise effect, then made a new camera and text layer. I made them 3D enabled. I have ray-traced enabled. I then pre-composed my background layer before right clicking and selecting "environment layer." My background layer then goes black.
It just seems so straightforward, I can't imagine where I'm messing up!
Brian Charles
on Nov 21, 2014 at 7:55:41 pm
Here's a demo.
Is the Comp panel set to Active Camera?
ENV2
Hannah Sander
on Nov 21, 2014 at 9:28:43 pm
Thanks Brian,
Here is what I just attempted:
Environment Layer test
When it goes to black (or checkerboard, when I have the BG set to transparent...) I can't rotate with the camera or anything. It's just like the layer vanished.
Hannah Sander
on Nov 21, 2014 at 9:42:38 pm
OH MY GOODNESS! I went back and studied the sample project you gave me and realized I was clicking the "Draft 3D" button (because that's what I thought I had to have selected to enable 3D layers...) AND HUZZAH! It worked!
Thank you so much for all the help, Brian!
Brian Charles
on Nov 21, 2014 at 10:22:05 pm
[Hannah Sander] "realized I was clicking the "Draft 3D" button"
That would do it! I done similar things myself, its how I learn.
