trouble with layers, imported illustrator file and such. CS6
Gary Martin
on Nov 18, 2014 at 7:58:34 pm
i have imported an illustrator file with 38 layers.
RGB, (i saved it as CC2014 and as CS6 and the same thing occurs.)
i import the file 'composition-retain layer size' and the file is imported with no trouble.
then i try and bring one of the layers into a new comp (NTSC D1 Widescreen Square Pixel at 29.97 fps/drop frame) sometimes AFX will place the AI layer onto the new comp but then won't let me bring in another layer.
Sometimes AFX will then remove the layer that i just brought in.
I can't arrange the layers in the comp created from the illustrator file either. (the illustrator file has a weird artboard size, 2044x578).
I've doubled checked the frame rates for both comps to make sure they match and have removed some older scripts from the scripts folder. this is very frustrating and i haven't found anything online that can address this problem. Can someone help me or has my software become possessed by a animation hating demon?
