Trapcode Particular - Freeze frame crashes AE
Chris Vo
on Nov 17, 2014 at 6:15:31 pm
I'm making a simple cloud effect with Trapcode Particular. I'd like to have the clouds stagnant (stop Particular from emitting new particles) so I precomped the clouds and enabled a Time Remap>Hold Keyframe which results in AE CC 2014 crashing.
Any ideas why this is happening? Any suggestions/workarounds would be greatly appreciated.
Chris
AE CC 2014 13.1.0.111
Mac OSX 10.9.5
Trapcode Particular 2.2.3
Michael Szalapski
Re: Trapcode Particular - Freeze frame crashes AE
on Nov 17, 2014 at 6:18:50 pm
I would suggest animating the time parameter in Particular instead of what you said. This allows you to move through the scene with the clouds frozen if you wanted to.
- The Great Szalam
Chris Vo
on Nov 17, 2014 at 6:44:31 pm
Thanks for the reply Michael.
Can you elaborate on how to set the time parameter for the Particular layer? Is it in the effect controls or are you referring to the layer properties? When I open up the time dialogue for the layer properties it only gives me two options.
Michael Szalapski
on Nov 17, 2014 at 6:47:27 pm
In Particular.
Under Physics>Physics Time Factor
- The Great Szalam
Chris Vo
on Nov 17, 2014 at 6:49:21 pm
Awesome, thanks!
Michael Szalapski
on Nov 17, 2014 at 7:06:59 pm
No problem!
- The Great Szalam
