Cut/Trim videofile.
ola sanda
Cut/Trim videofile.
on Nov 15, 2014 at 6:45:13 am
Hello.
I want to import a video file, which is 25 minutes long, but I only need a 10 seconds part of this video.
Do I have to cut out these 10 seconds in an editing program, such as Final Cut/Premiere Pro, before importing to AE, or can I do this in AE ?
Ola
Tudor "Ted" Jelescu
Re: Cut/Trim videofile.
on Nov 15, 2014 at 7:05:31 am
you can cut the 10 sec in AE - why would you use a editing program?
Tudor "Ted" Jelescu
Senior VFX Artist
ola sanda
on Nov 15, 2014 at 9:05:33 am
OK, thanks Ted.
Do I do it in the timeline, meaning taking the 25 min. video into the composition and then trim it ?
Or can it be done while creating the composition somehow ?
Ola
John Cuevas
on Nov 15, 2014 at 12:13:10 pm
Probably the easiest way would be to import your video, and double click your video while it's in the project window. Navigate to your in point and use the "set in-point" button below the video, do the same for the out point, then drag it on to the make new comp button.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
ola sanda
on Nov 15, 2014 at 12:19:38 pm
Thanks a LOT Johnny, I will try just that ! :-)
Ola
Tudor "Ted" Jelescu
on Nov 15, 2014 at 12:31:46 pm
John gave you the answer to that one.
Tudor "Ted" Jelescu
Senior VFX Artist
Todd Kopriva
on Nov 15, 2014 at 4:09:02 pm
One of the first things shown in this basic three-video introduction to After Effects is trimming:
https://helpx.adobe.com/after-effects/how-to/add-effects-motion-graphics.ht...
I recommend that you start here to learn After Effects:
http://adobe.ly/AE_basics
After Effects product manager and curmudgeon
After Effects team blog
ola sanda
on Nov 15, 2014 at 4:52:04 pm
Thanks Tod :-)
