Export 16bit Sequence From AME
Tav Flett
on Nov 7, 2014 at 2:22:37 pm
Hi there,
I was wondering if it is possible to output a 16bit TIFF sequence from adobe media encoder?
I am currently working on a 16bit AE project and have tried sending my final output composition to the AME however it only seems to render at 8 bit.
I have checked the render at maximum bit depth option and maximum quality however it still only renders 8 bit and cant find any other bit depth options.
Any ideas?
Cheers,
Tav
Dave LaRonde
Re: Export 16bit Sequence From AME
on Nov 7, 2014 at 5:11:04 pm
You need to make a custom AME preset for that. It isn't difficult. Nose around: you'll figure out how to do it.
Dave LaRonde
Promotion Producer
Brian Charles
on Nov 7, 2014 at 6:31:15 pm
@ Dave. I've nosed around in AME and cannot locate an option for 16bit TIFF sequences. Where do you find it?
Dave LaRonde
on Nov 7, 2014 at 6:40:58 pm
Sorry, don't have access to AME on this particular machine.
Dave LaRonde
Promotion Producer
Tim Kurkoski
on Nov 10, 2014 at 8:11:55 pm
Adobe Media Encoder doesn't have larger than 8bpc for the still image formats.
I recommend you use the Render Queue in After Effects for still image sequence exports of After Effects comps, for this and other reasons (alpha channel support, output file naming templates).
