AE Preset From Multiple layers?
Tav Flett
on Nov 7, 2014 at 11:09:56 am
Hi there,
I was wondering if it is possible to make an effect preset from multiple layers?
I have 3 solid layers that I am using to create a chromatic aberration effects and was wondering if it is possible to save these 3 layers as 1 animation preset.
I haven't had any luck yet with more than one layer and was reading that the best way to do this is with .jsx scripting.
The script editor is impenetrable as I am no coder so was wondering if there's is an easier way to do this? In Nuke you can easily set up Macro's with a string of nodes which is I guess what I'm after.
Dave LaRonde
Re: AE Preset From Multiple layers?
on Nov 7, 2014 at 5:15:05 pm
Nope! Can't do that. But here's what you CAN do:
Get your chromatic aberration comp loooking the say it should. Delete EVERYTHING ELSE but what's necessary to create this.
(It goes without saying that this should be done in a duplicated project.)
Then Reduce your project. Save it with the innovative name, "Chromatic Aberration".
Then when you need such a thing, import the project into your current project and replace footage.
Dave LaRonde
Promotion Producer
Kevin Camp
on Nov 7, 2014 at 10:40:09 pm
your other option would be to have 3 presets, one for each layer. something like 'chromatic aberration red', 'chromatic aberration blue', 'chromatic aberration green'....
Kevin Camp
Art Director
© 2018 All Rights Reserved
