Trying to figure out a particular transition
Mark Pirres
on Nov 5, 2014 at 5:31:14 pm
Hello,
I'm trying to figure out the technique used in the following video https://vimeo.com/77127939 at:
- 00:25: there's a cross fade but the clips seems to brighten up too?
- 00:35: is it a flare coming through from below? or a light built in after effect? (which sort?)
I have thought both the above might have been the results of some light source coming in during the actual shooting, but I still think it's an added effect - am I wrong?
thanks
Dave LaRonde
Re: Trying to figure out a particular transition
on Nov 5, 2014 at 5:36:08 pm
Nothing fancy in those two. One animates the opacity of a color solid above the transitioning layers -- either a cut or a dissolve -- and the other just uses a blur in combination with a pretty standard transition. Very simple to do.
Dave LaRonde
Promotion Producer
George Goodman
on Nov 5, 2014 at 9:12:44 pm
First is a fade through white and the second looks like maybe a little film burn overlay with a cut in the middle. I bet you'd like film burns even though they're a liiiiiiitle bit different.
This video has 5 free ones:
"|_ (°_0) _|"
Sincerely,
George
http://www.vimeo.com/georgegoodman
http://www.linkedin.com/in/georgefranklingoodman
Mark Pirres
on Nov 6, 2014 at 11:31:58 am
Thanks both for this, although Dave I think you misunderstood the second transition (maybe there was a lag with the playback): I meant the shot where there is a table with a vase of flowers on it and then it changes to a field with a tent on the back.
George I'm not 100% sure is a film burn though (I meant to write film burn in my first post instead of flare); it seems to come up from the lower part of the frame in a very steady way, while film burns seem to flicker quite a lot. You would rule out a light was created in After Effects (or similar) then?
George Goodman
on Nov 6, 2014 at 9:53:25 pm
Ya, that second transition probably isn't a film burn, just similar.
There are a lot of ways to do the second one. You could use a solid or shape layer that is a pale yellow move it downward so its about halfway covering the bottom of the frame, add a blur, change the blend mode to overlay, add or multiply (play to see what you like) and fade in and out the opacity and cut the video in the middle.
"|_ (°_0) _|"
Sincerely,
George
