Media offline in Premiere Pro after closing After Effects
Darius Cornean
on Nov 4, 2014 at 1:40:09 pm
I have a problem that I struggled for several days.
I have a project filmed with two cameras in Premiere Pro. I created a nested sequence where we made ​​multicam editing. Then I created several sequences where I put parts from the multicam sequence. Then I sent these sequences in After Effects where I made ​​a noise correction with Neat. I saved the project in AE and then I closed. And in Premiere appeared that all files of those sequences are offline.
If I keep open After Effects the file in premiere Pro are ok, does not appear media offline.
Another very important issue, Render works very hard and does not understand why.
I use CUDA for render. I really need some solutions.
Thank you!
iMac 27, 3.5, SSD, 8GB RAM, video card 4GB
Dave LaRonde
Re: Media offline in Premiere Pro after closing After Effects
on Nov 4, 2014 at 4:31:36 pm
You've placed an AE comp into a PP timeline. PP may use Cuda for rendering, but AE does NOT. You can't make AE use Cuda, either. So there will be rendering time involved.
Dave LaRonde
Promotion Producer
Daniel Waldron
on Nov 4, 2014 at 9:44:08 pm
8GB of RAM isn't going to set any speed records either. The Neat noise removal plugin is great, but it also is a resource hog. I would shut it off until you are ready to export.
