time remapped 50fps footage creating uneven juddery playback
jesse richards
on Nov 3, 2014 at 11:13:06 am
Hi
I have picked up an edit of some 50fps footage intended to be played back at 25fps for a slow mo look.
Most of the shots work well but there are a few sections where the footage has been time remapped at different rates which is basically causing jumps in the frames (ie it will play frame 1 -3 -5 then 6 for example)
The edit is locked and I just wondered if anyone had any ideas about how to counter this problem?
Cheers
Jesse
Dave LaRonde
Re: time remapped 50fps footage creating uneven juddery playback
on Nov 3, 2014 at 5:41:56 pm
You could try the Time Warp effect. It's tougth to say whether it'll do the trick for you, but it's worth a shot.
Dave LaRonde
Promotion Producer
Buddy Brett Ramker
on Nov 5, 2014 at 6:17:43 pm
If the footage is retimed to 50% then the playback should be smooth if said footage was really shot at 50p. Instead of retiming to the footage you can interpret it to 25p resulting in a natural slow down. Since you are trying to get slow motion playback with footage that was shot 50p I would avoid timewarp. That effect only works well with a good Hi C shot, and even then it requires a lot of fiddling and rendering.
Best,
Brett
Dave LaRonde
on Nov 5, 2014 at 6:34:12 pm
I totally agree. But since this is one of these instances of trying to make chicken salad out of chicken s**t, the guy's gotta try, no guarantees of success offered.
It'll be a good lesson, learned the hard way: don't fart around with non-standard frame rates in a standard frame rate comp.
Dave LaRonde
Promotion Producer
