Replacing a Blown Out Screen with Power Point JPEGs
Mark Hinchey
on Oct 28, 2014 at 9:50:07 pm
Hello,
I shot a video of a lady giving a presentation which was accompanied by a Power Point slide show projected on a screen. In the video the screen is not really visible so what I want to do is remove it, essentially leaving a transparent hole. I will then layer JPEGs of the original Power Point over the hole.
However, the lady occasionally walks in front of the screen so I will need to mask around her when she does.
I am new with AE so I really don't know the best way to go about doing this. Can anyone point me in the right direction?
Thanks in advance!
Walter Soyka
Re: Replacing a Blown Out Screen with Power Point JPEGs
on Oct 29, 2014 at 6:20:00 pm
Is the shot locked down, or does the camera move?
If the screen is totally blown out, I'd probably try to start with pulling a luma key (use the Extract effect to key out the blown out whites).
Walter Soyka
Mark Hinchey
on Oct 29, 2014 at 7:30:15 pm
Thanks for the response Walter! The shot is locked off. The screen isn't completely blown out, just enough to make it un-readable. Assuming I did use the luma key, how would you go about masking around the presenter as she walks in front of the screen?
