Placing a bunch of comps on a percise triangular grid
dor peer
on Oct 28, 2014 at 5:19:39 pm
Hello!
I want to place many copies of the same pre-comp on a precise triangular grid.
Here is a visual example:
Is there a way to do it precisely? They don't have to do anything special but the initial placement should be precise.
Jeff Salman
Re: Placing a bunch of comps on a percise triangular grid
on Oct 28, 2014 at 9:20:01 pm
Hi dor peer,
What is the graphic in the precomp that you're trying to place? B/c - in my mind - the correct approach will depend on what is in that precomp. For ex., in the visual example you gave, if the precomp is one of those dots, then I would do it differently than if the precomp is a triangle made up of three of those dots.
Let me know and I'll see if I can help. And maybe you can post a pic of the precomp ... that may help in figuring out exactly what you're trying to do.
dor peer
on Oct 29, 2014 at 9:02:09 am
The precomp is made of a single dot resembling a small light
Walter Soyka
on Oct 29, 2014 at 6:25:13 pm
You could use a grid arrangement script:
http://aescripts.com/layers2grid/
http://aescripts.com/gridder/
You may have to select every other row and offset them.
Walter Soyka
