Simple Masking Problem
Lewis Lloyd
on Oct 24, 2014 at 1:08:17 pm
Hi guys, I think I'm just being stupid, but I'm trying to mask out both images in this Daguerrotype to use as an overlaid frame for 2 videos. So I want to get rid of the 2 girls and have a transparent background, so I can stick some videos in there.
I'm sure it's the simplest of tasks, but when I put 2 masks on the same image it reveals the other side if it's inverted or vice versa. Makes sense really. What obvious method am I not understanding here? Any suggestions much appreciated! Thanks!
Lewis
John Cuevas
Re: Simple Masking Problem
on Oct 24, 2014 at 2:30:51 pm
Don't invert your add mask, instead make it a subtract mask
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Lewis Lloyd
on Oct 24, 2014 at 2:58:37 pm
Thanks Thomas!
I didn't see your post till now, but worked it out in the meantime!
Thanks for your time!
Lewis
Lewis Lloyd
on Oct 24, 2014 at 2:57:23 pm
I worked it out!
Locked the first mask and changed the blending mode on the other one and it was fine.
Hope nobody wasted 30 seconds reading this!
Dave LaRonde
on Oct 24, 2014 at 4:25:27 pm
I recommend playing with multiple masks on a layer, then changing the mask modes to see what happens. You'll learn a lot that way.
Dave LaRonde
Promotion Producer
