After Effects Won't Render AVIs
Chris Kay
on Oct 24, 2014 at 4:46:45 am
I now work with AE CS6.
I used to work with CS4.
In CS6, when I set my render up as an AVI with No Video Codec and RGB + Alpha it doesn't work. The render will complete and the video will play, but some frames are filled with large grey palettes (kind of like a no reception screen on TV filling a portion of some frames).
Can anyone recommend me another format I can use for RGB + Alpha export (i want to use it in Premiere) or a solution to the problem?
John Cuevas
Re: After Effects Won't Render AVIs
on Oct 24, 2014 at 11:48:45 am
Do you really need to render, you can dymanic link in CS6 to Premiere, open Premiere and import the AE project.
If you really need to render out, I use Avid's Codec DNxHD codec, it will create a quicktime file. Otherwise, if you are going for lossless, Quicktime Animation---large file size though.
Johnny Cuevas, Editor
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
© 2018 All Rights Reserved
