Infinite "ground"
Colin Peterson
Infinite "ground"
on Oct 21, 2014 at 10:14:26 pm
I'm trying to have a ball 'roll' down a hill for an infinite amount of time, I have the ball rolling and rotating on the ground, and I've used Motion Tile on the ground to stretch it. But to create the idea of motion, I need to move the ground backwards, and eventually I run out of ground layer, because Motion tile won't continue on forever. What should I be doing? Do I create a loop of the ground in a precomp? Or is there an easier way to do this... Thanks for any input!
Dave LaRonde
Re: Infinite "ground"
on Oct 21, 2014 at 11:05:13 pm
Instead of Motion Tile, you could use an oldie but a goodie: The Offset Effect. It the top & bottom of the "ground" image are seamless, it should work.
Dave LaRonde
Promotion Producer
Kevin Camp
on Oct 21, 2014 at 11:49:18 pm
motion also has an offset feature, though it's less intuitively named 'tile center'.
if you animate the tile center y component, you should be able to make it look like is moving, rather than animating the position property.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
