New After Effects 2014.1 "The importer reported a generic error"
Roberto Conti
on Oct 17, 2014 at 12:21:26 pm
Hi, all!!!!
i got a problem with AE 8.1 (updated to 17 october 2014).
When i try to substitute an after effects composition on premiere it says that "the import program has encountered a generic error" then it open the composition, but it's not tie to premiere...
I can't figure it out...Before 8.1 it worked very well....
Thanks if someone can help me....
I found a solution!!!!!!
"The importer reported a generic error" And/OR CC 2014 keeps asking me to license the software even after I successfully license it.
Adobe Tech Support: Please disable the firewall and antivirus temporarily for few minutes so that we can isolate the issue better.
Adobe Tech Support: Please press windows are R key to open the run search box.
Adobe Tech Support: Then type there below command and hit enter.
Adobe Tech Support: inetcpl.cpl
Adobe Tech Support: Please click on connections tab.
Adobe Tech Support: Then select LAN settings.
Adobe Tech Support: Then tell me which boxes are marked check.
Adobe User: none
Adobe Tech Support: Please mark check on automatically detect settings.
Adobe Tech Support: Uncheck all the other boxes.
Adobe Tech Support: Then click on OK.
Adobe Tech Support: Then apply and OK.
Adobe Tech Support: Then try to open the CC product sign in if ask.
Adobe Tech Support: Then after license close it and re-open to check the issue.
Roberto Conti
Re: New After Effects 2014.1 can' do dynamic link.says the import program has encountered a generic error
on Oct 17, 2014 at 4:21:46 pm
Ok i found an working solution for whom that may have the same issues!
Adobe User: none
