turtorial of this motion graphic (http://vimeo.com/102327078)
Ed Home
on Oct 17, 2014 at 10:57:41 am
Hi everybody,
The link attached beneath is the way my client likes to have it's movie too. I mean the way of morphing and especially the way the lines animate.
Does anybody know a good turtorial where the way of animating these lines are explained? Starting from 18 seconds, the way the tubes animate
I hope somebody can help me....
Thx
Edith
Daniel Waldron
Re: turtorial of this motion graphic (http://vimeo.com/102327078)
on Oct 17, 2014 at 12:58:27 pm
You probably want to start by learning about shape layers.
Ed Home
on Oct 17, 2014 at 1:40:35 pm
thx I will have a look at that
Tim Bentley
on Oct 18, 2014 at 1:41:09 pm
This tutorial uses pretty much the same techniques though it'll only get you some of the way there.
http://lesterbanks.com/2013/03/animating-morphing-pictograms-in-after-effec...
New film just added: http://timbentley.info/
Jason Jantzen
on Oct 18, 2014 at 7:48:11 pm
Just a warning about using shape layers. Make sure you build them out of bezier shapes if you want to animate the paths. They still haven't fixed the issue where the shape does a weird morph instead of animating after converting a parametric shape to bezier. Just check the "Bezier Path" box on the tool bar before making your shapes.
Jason Jantzen
vimeo.com/jasonj
Ed Home
on Oct 19, 2014 at 4:51:18 pm
Guys, thank you all for the replies!!!!
I'm gonna use your tips and info
JP Pelc
on Oct 20, 2014 at 9:20:21 pm
Looks like a lot of time animating shape layers
