Doubts about Pixel Ratio for a TV Spot + best images resolution
João Queirós
on Oct 17, 2014 at 10:16:06 am
Hi guys,
I´m doing the illustration for a animation for a tv spot. I´ve the resolution for it 720x576. Then i was doing a quick test in AE, and was trying to choose the pixel ratio, but i´ve doubts. Please check the pdf with the information required from the tv chanel.
http://www.mediafire.com/view/om2kr54j6ks1ps9/Omneon_format_Nov_2010.pdf
Should i choose in the preset "PAL D1/DV Square Pixel"? if yes what should i choose in pixel aspect ratio? I can´t find this aspect ratio from the pdf "Display aspect ratio: Original (4X3 or 16X9)". Even chosing this "PAL D1/DV Square Pixel" i´ve to change manually the resolution, because the one by default is 788x576.
I´m afraid i´m doing something wrong here, that´s why i´m asking for your help guys.
By the way, i will do 2D animation, mixed with stop motion. What should be best size for my images? Save them as PNG should be fine right?
Thanks in advance.
Kindly Regards,
João
http://www.joaoqueiros.com/uk_index.php
Tudor "Ted" Jelescu
Re: Doubts about Pixel Ratio for a TV Spot + best images resolution
on Oct 17, 2014 at 10:43:56 am
The PAL format has the following format sizes when you use square pixel:
4:3 = 768×576
16:9 = 1024x576 ( Adobe has decided 1050x576 is the "true" size )
The question to ask is how will this be seen by most viewers - in a 4:3 frame (older tv sets), a stretched 4:3 to a 16:9 (new 16:9 tv sets). Depending on that you can use the 4:3 or 16:9 square pixel format to create your animation. The final result will be squeezed in a 720x576 frame anyway it seems from the station's specs. So ask them if they recommend the 4:3 or widescreen based on their research.
What I recommend is to use a 1280x720 square pixel (16:9) frame to create you animation. Once you have a final render, create a PAL SD comp, drag your finished render in it and resize to fit the Height of the frame. Then, based on the final decision - 4:3 or 16:9 - leave the frame cropped for 4:3 or squeeze (resize) the width to fit the 720.
Tudor "Ted" Jelescu
Senior VFX Artist
Dave LaRonde
on Oct 17, 2014 at 4:57:45 pm
I agree with Ted. The first thing to do is to find out if you have to make 4x3 or 16x9 video.
Dave LaRonde
Promotion Producer
João Queirós
on Oct 17, 2014 at 5:14:08 pm
Thanks Dave. Yes agree.
João Queirós
on Oct 17, 2014 at 5:11:51 pm
Hi Jelescu,
Thanks you so much for your quick reply. This is the 1st time i´m doing animation for TV, that´s why i´ve many doubts, and i want to be sure what i´m doing.
This will be used in european tv, it´s for a kids tv chanel, i believe it is this option "a stretched 4:3 to a 16:9 (new 16:9 tv sets)"
Yes your recomendations looks really good. I will try to call them to understaind all this. Because if i use the 1280x720 square pixel (16:9), i will need to adapt my illustrations scenario that i was doing in 720x576.
Can you tell me the name of the preset in the "Composition Settings" to create the PAL SD comp? And.. if i resize the height of the 1280x720 frame to 720x576 this will not unformat Jelescu?
I will let you know when i have some answer from them. Thanks again.
Kindly Regards,
João
Tudor "Ted" Jelescu
on Oct 20, 2014 at 7:24:32 am
Ted would do just fine- only my grammar school teacher called me by my last name.
Working in 1280x720 will allow you to get a good quality final product. The trick is to figure out the final format of the frame- 4:3 or 16:9 so that you can arrange your graphic elements. You can always be safe and work with 4:3 in mind.
For output presets from AE you can check out the Adobe help.
Tudor "Ted" Jelescu
Senior VFX Artist
João Queirós
on Oct 27, 2014 at 10:40:26 pm
Ha ha, Sure Ted : )
The final format is 4:3. I´m working 720x576 because in the channel they ask me to do it. But i think your way is better Ted working first 1280x720 because of the quality and in the end adapt the resolution to 4:3. Thank you so much for the sharing Ted.
About the preset the one that i´m working is PAL D1/DV Square Pixel.
thank you guys.
Kindly Regards,
João Queirós
