Creating a Mask That Affects All Layers Below
James Gordon
on Oct 15, 2014 at 9:12:17 pm
I'm creating some projection mapping content in After Effects. The building wall I'll be projecting on to has several windows that I don't want anything to shine into from the projector.
I've created a black and white psd file of the wall with the windows black and the rest of the wall white.
Is it possible to use this B&W image as a top layer matte in order to mask out the window area of all the content layers and comps I place below it?
I've tried a luma track matte which worked but only affects the layer immediately below it.
As I type this I just got the idea that maybe the simplest thing to do is to create a psd top layer that just has black where the windows are and is transparent everywhere else (instead of white).
Still curious though about the possibility of a top level matte that affects all below it. Thank you.
Roland R. Kahlenberg
Re: Creating a Mask That Affects All Layers Below
on Oct 16, 2014 at 11:36:05 am
The mask or layer with the 'master' Alpha Channel should be placed at the very top of the layer stack - then set its Blending Mode to Stencil Alpha.
HTH
- Roland
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
James Gordon
on Oct 17, 2014 at 5:43:15 pm
thank you so much Roland!
