Dynamic Particles? Move particles on impact with object?
Moog Gravett
on Oct 14, 2014 at 9:04:08 am
Hi folks,
I'm about to start playing to see if I can get particles being pushed around by an object. My foundation is to see if there's a way, in particular, to have a static particle field that gets knocked about when something flies through it. I'm going to try using a solid as a collision object, then move it in 3d space.
That's the plan anyway, but I'm sure it's not going to be as simple as that. So has anyone got any tips or ideas tat I can pick up on?
Cheers,
Moog
Roland R. Kahlenberg
Re: Dynamic Particles? Move particles on impact with object?
on Oct 14, 2014 at 11:38:30 am
Particular + Newton - these examples should give you an idea.
HTH
- Roland
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
Moog Gravett
on Oct 14, 2014 at 11:43:37 am
Thanks for the suggestions, I'll take a look.
Matthew Keane
on Oct 18, 2014 at 11:39:55 am
Not as realistic as Newton, but if you just need particles to be pushed out of the way, you could try linking the position of the Spherical Force Field in Particular to the position of your other object. It's a quck and easy way to make it look as though particles are reacting to something.
Matthew Keane
Freelancer based in Paris, France
- Motion Graphics, Video Editing & Effects, Watchout Programming & Live Operation.
