Function Co-ordinates Missing
Qi Lin
on Oct 12, 2014 at 2:07:19 pm
Would need some help here!
Currently using AE CS6, OS X Mountain Lion
When I reopened my AE file and created a black solid, the Co-ordinates functions for all of my "Transform" tools went missing. Thus, I'm unable to change the values of any of the tools, as they disappeared.
A few hours ago, I'm able to use my program as per normal. Are there any settings that may have been toggled off?
John Cuevas
Re: Function Co-ordinates Missing
on Oct 12, 2014 at 5:32:55 pm
Most likely you hit the Collapse/Expand columns button in the bottom left corner of AE. To expand press "Shift+F4". Pressing "F4" will toggle between "Transfer Modes" and the "Switches", switches is the column that has your transform tools.
Also you can choose what you want to show, by right clicking above your layers names and choosing "Columns".
Johnny Cuevas, Editor
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
© 2018 All Rights Reserved
