After Effects CS6 CC Particle World
Dite Cepule
on Oct 9, 2014 at 10:11:37 am
Hey,
I have to make an animation where many shapes with the same properties move across the screen in a straight line (with same spacing in between).
I was wondering if instead of animating each shape I could use CC Particle world. So far I have created particle system where same size particles move in a line, but I still struggle with having them moving in a straight line and more importantly - having same distance in between. Is that even possible and, if yes - I would appreciate the help.
Walter Soyka
Re: After Effects CS6 CC Particle World
on Oct 9, 2014 at 1:23:23 pm
Assuming you are using a shape layer, how about using a repeater [link]?
Walter Soyka
Dite Cepule
on Oct 9, 2014 at 2:08:31 pm
No, unfortunately it's not a shape layer, but a part of illustration.
Walter Soyka
on Oct 9, 2014 at 2:13:22 pm
This is probably easier to control with Dan Ebberts's "follow the leader" expression than with a particle system:
http://www.motionscript.com/mastering-expressions/follow-the-leader.html
Walter Soyka
