Prevent Outline When Using Iris Wipe Preset
Kevin Davie
on Oct 3, 2014 at 5:20:25 pm
Hi Everyone, although this is my first post, I've basically been living in this forum over the past few months. It's provided me with a very helpful kickstart for an AE project I'm working on (my first AE project). Apologies if this question has been asked before, I did search for a solution, but was unable to find anything that seems to fit my situation...
I have applied an animation preset from my main composition on 2 separate pre-comps. I'm using the Iris Square Wipe one (Presets>Transitions-Wipes>Iris-Square). The first pre-comp on my timeline transitions with the square collapsing, and the second one transitions with the square expanding. My issue is that I am getting outline artifacts around the object within the second pre-comp. So even though there is a box expanding from center out, you can see the outline of the entire object. Any advice on how to get rid of the outline is appreciated.
-Kevin
Roland R. Kahlenberg
Re: Prevent Outline When Using Iris Wipe Preset
on Oct 5, 2014 at 3:08:32 am
Simple Choker should do the trick to remove a halo.
HTH
- Roland
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
