take an object png and create drop shadow
anita sancha
on Oct 3, 2014 at 1:38:48 pm
Hi...
How can I take an object and create drop shadow onto other objects. without having the shadow appear on the transparent background.
i.e 2 layers
cup on saucer.
cup layer 1
saucer layer 2
background transparent
the shadow of the cup ONLY on the saucer NOT the transparent background layer.
Thanks for all your help
Anita Sancha.
http://www.anitasancha.co.uk
anita sancha
Re: take an object png and create drop shadow
on Oct 3, 2014 at 1:39:27 pm
After effects 5.5
Anita Sancha.
Walter Soyka
on Oct 3, 2014 at 1:45:09 pm
Don't use the drop shadow effect or layer style. Instead, use 3D layers and a light to cast the shadows:
http://helpx.adobe.com/after-effects/using/3d-layers.html
Walter Soyka
anita sancha
on Oct 3, 2014 at 2:03:46 pm
Hi.... Thats a solution... but the actual project is large and using lights changes the flat 2D style I hope to keep. Lighting takes it on to a whole new "feel" great though it is I was hoping not to go 3D...
so would really appreciate a 2D solution if there is one !!!
Anita Sancha.
Walter Soyka
on Oct 3, 2014 at 2:31:46 pm
[anita sancha] "using lights changes the flat 2D style I hope to keep. "
If you set a layer's "Accept Lights" property to off (in its material settings, tap AA with a layer selected to reveal), then it will not be shaded by lights. It can still cast shadows.
[anita sancha] "so would really appreciate a 2D solution if there is one !!!"
You can fake it with a bunch of compositing:
1. Top Layer
2. Bottom Layer (invisible)
3. Top Layer (Drop Shadow Effect with Shadow Only option, Alpha Track Matte set)
4. Bottom Layer
Walter Soyka
anita sancha
on Oct 3, 2014 at 2:40:51 pm
PERRRRRRFECT 2D solution using the alpha matt... just what I wanted.... internet "KISSSSES" and HUGGS
Anita Sancha.
