continuous footprints with trail at centre of screen
Nick Frewin
on Oct 2, 2014 at 11:44:28 am
can anyone point me in the right direction..
i want to create a trail of footprints that are centred on the screen (with the footprints scrolling off to the left as the new ones appear in the centre).
I can do this manually easy enough, but there must be a cleverer way using effects/expression to do this?
John Cuevas
Re: continuous footprints with trail at centre of screen
on Oct 2, 2014 at 1:50:38 pm
Have you tried using one of the particle generators(I'd use particular)? That would be a pretty easy way to create footprints.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Nick Frewin
on Oct 2, 2014 at 2:19:55 pm
i've not tried a particle - i can vaguely see how that would work
this is where i'm at
currently i have 8 seconds of footprints, which i'm then just duplicating / shifting horizontally
Brian Charles
on Oct 2, 2014 at 2:18:14 pm
Shape layers with a repeater?
8058_footprints.aep.zip
Nick Frewin
on Oct 2, 2014 at 2:46:20 pm
that's perfect thanks
