How can I replicate this zoom in twist effect?
David Honan
on Sep 30, 2014 at 5:00:22 pm
Hi from not raining anymore 22 degrees C York Uk :-)
In After effects (Ive got CC but mm a bit of a rookie) I'd like to replicate the effect seen in this video
@ 12 seconds. Really like how pic twists and jump cuts.
Any advice welcome :-)
John Cuevas
Re: How can I replicate this zoom in twist effect?
on Sep 30, 2014 at 5:44:31 pm
First, the picture is much bigger than the final composition, this is important so when you zoom/scale it doesn't ter. The twists are achieved, by using rotation, scale and anchor point keyframes. The jumps aren't even really jumps(you can see this playing frame by frame), but quick zooms, moves with a glow effect that ramps up and off quickly.
This is all pretty basic stuff, so I would strongly suggest you check out: Getting started with After Effects (CS4, CS5, CS5.5, CS6, & CC)
Learn After Effects CC
Learn the basics of After Effects CC with tutorials by experts.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
David Honan
on Oct 1, 2014 at 9:02:20 am
Grazie mille John :-)
