Finding the position of a layer once its anchor point has been changed.
Tom Holmes
on Sep 26, 2014 at 2:39:36 pm
Hey Guys!
So, say if you have a null object and you adjust the anchor point parameter in the layer properties..The anchor point will stay where it is and the object/layer will move by the amount (and in the direction) as changed by the anchor point... this means you can now rotate the null around that point to create a circle...
With me so far?
How do i find out the new position on the null object (not its anchor point) so that as it rotates around the anchor point (and as a result move around the comp) i know its position as it moves, as the position property only tells me the anchor points position.
Please advise guys!
Thanks!!!
Tom :)
Michael Szalapski
Re: Finding the position of a layer once its anchor point has been changed.
on Sep 26, 2014 at 3:32:15 pm
I would use two nulls for that. One parented to the other. Then use the toWorld() expression to find the position of the parented null.
- The Great Szalam
