Premiere Pro CC Prores problems
Felix Crull
on Sep 25, 2014 at 3:41:18 pm
Hi all
all of a sudden my Premiere does not import mov-files encoded in Prores 422 - that is: just the audio track is imported.
Media Encoder as well cannot handle prores-files any longer.
Re-installing Premiere and Quicktime did not help. The Prores codec seems to be broken. Does anybody know how to delete this codec in order to re-install it?
Prores installation quits with "A later version of Apple Quicktime Prores decoder is already installed on your computer."
Also starting AME or Premiere takes ages...
Seems to stall when Quicktime codecs are loaded.
Help needed - thanks a lot in advance!
felix
Win 7 - AME 7.2.0.43 - Premiere Pro CC 7.2.1 (4)
Michael Szalapski
Re: Premiere Pro CC Prores problems
on Sep 25, 2014 at 4:02:02 pm
Try this: http://blogs.adobe.com/aftereffects/2011/02/troubleshooting-quicktime-error...
- The Great Szalam
Felix Crull
on Oct 7, 2014 at 10:23:36 am
Thanks for the link -
which unfortunately didn't help with my problems.
In the end de-installing all related software and re-installing (premiere, QT, Java, Flash, Adobe Air, graphic card driver) in a new admin-account did the trick.
Thanks anyway.
felix
chris king
on May 26, 2015 at 8:50:26 am
Actually, ProRes in a MOV file format is beyond the compatibility of Adobe Premiere Pro. You can’t get a flawless workflow in most cases. To solve the problem, you need to change ProRes files to Premiere Pro CC most compatible format like MPEG-2.
Tero Ahlfors
on May 26, 2015 at 10:38:40 am
[chris king] "Actually, ProRes in a MOV file format is beyond the compatibility of Adobe Premiere Pro."
Actually, you have no idea what you're talking about. I use it daily on Windows and Mac machines on Premiere pro without any problems.
Michael Szalapski
on May 28, 2015 at 6:03:17 pm
You are suggesting taking a PRODUCTION codec that IS USEABLE and encoding it into a lossy deliverable codec for production work? That's...not good advice at all.
- The Great Szalam
