• | relink mpeg footage
on Sep 25, 2014 at 7:34:46 am |
Hello.
I'm opening up an old AE project and trying to relink the media gone offline by using the "replace footage" option.
The media files are mpegs and they were originally shot on a JVC GY-HD100. When I replace a media file, it shows up funkily, stating things as the file being 0,027 fps or the duration only being few frames long etc. When I then double-click on the click from the project window to screen the footage in a source monitor, it's blank (black monitor). The same thing is happening when I simply open the clip in my QuickTime player, which opens the clip but won't play it, there is only a blank, black monitor. In VLC player though, I can play it.
I might add that I'm working on a macosx and on AE6.
Does anybody have a suggestion for me?
Best regards.
• | Re: relink mpeg footage on Sep 25, 2014 at 7:43:32 am |
Here is more informations about the mpeg files:
Bit rate : 18.3 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.397
Stream size : 54.1 MiB (92%)
Audio
Menu ID : 1 (0x1)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 3
Duration : 25s 152ms
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 1.15 MiB (2%)
Menu
Menu ID : 1 (0x1)
List : 4096 (0x1000) (MPEG Video) / 4098 (0x1002) (MPEG Audio)
Maximum bit rate : 19760000
• | Re: relink mpeg footage on Sep 25, 2014 at 4:08:11 pm |
What is the full version number of AE that you're using?
Although, if you can't see the files playing correctly in another media player, that's a pretty good indication that there's a problem unrelated to After Effects.
Have you installed any codec packs on the system? (K-Lite and others can cause odd issues like that.)
- The Great Szalam
• | Re: relink mpeg footage on Sep 26, 2014 at 3:00:57 pm |
Thanks.
No, no codec packs.
I went back to AE CS5.5, and there is no problem there... go figure.
• | Re: relink mpeg footage on Sep 26, 2014 at 3:23:18 pm |
Odd. Well, I'm glad you got it working.
- The Great Szalam
