Need advice with Comp Settings
Justin Cordle
on Sep 20, 2014 at 2:26:41 am
I need to setup a comp with the following settings (see photo) Can't seem to find the NTSC - CCIR 601/DV option.
Also can't seem to find the 9:10 Pixel aspect ratio option.
I am working in Adobe AE CC 2014
Any help would be very much appreciated!
Justin C.
Roland R. Kahlenberg
Re: Need advice with Comp Settings
on Sep 20, 2014 at 4:14:09 am
The NTSC D1 preset should be what you're looking for.
HTH
- Roland
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
Justin Cordle
on Sep 20, 2014 at 4:19:57 am
Thank you so much! That helps me want to let you know :-)
Do you have any insight into that 9.10 pixel aspect ratio?
on Sep 20, 2014 at 4:35:56 am
In AE, when youpick a preset, the pixel aspect ratio comes along for the ride. AE's settings are accurate. The settings you provided shows a discrepancy - 720x486 is NTSC D1 while 720x480 is NTSC DV. Just select the NTSC D1 preset and you should be good to go.
Cheers
- Roland
Justin Cordle
on Sep 20, 2014 at 5:17:08 am
Thank you so much, I was so confused. I will make sure that those idiots that sent me the specs realize that they are wrong. You've been a huge help!
