back of rotating image
stig olsen
on Sep 17, 2014 at 2:29:52 pm
Is it possible to attach an image or another comp to the back side of an another image?
Like if I have an image rotating all the way around I want this new image on the back side to be visible.
Stig
Walter Soyka
Re: back of rotating image
on Sep 17, 2014 at 3:18:12 pm
Dan Ebberts and expressions to the rescue:
http://www.motionscript.com/design-guide/invisible-facing-away.html
Walter Soyka
chris brett
on Sep 17, 2014 at 3:31:27 pm
Hi --- if you dont fancy that all you have to do is this -
1 ) put reverse on a second layer 1 pixel back in z space
2 ) precompose front and back layers
3 ) rotate precomp -- et voila ........
---------------------------------------------- chris --
Brian Charles
on Sep 17, 2014 at 3:35:42 pm
One more method: Card Wipe with Rows and Columns set to 1.
7997_cardwipe.aep.zip
John Cuevas
on Sep 17, 2014 at 3:59:51 pm
Wish I'd seen this last week. Just completed a slide show presentation video, 600+ pictures rotating and this would of been a much better method than my approach. I should run all my projects by Dan before I start... :)
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
chris brett
on Sep 17, 2014 at 3:36:46 pm
Hi --- just remebered sometimes I keep the z space the same and anumate transparency at the point of transition --- chris
stig olsen
on Sep 18, 2014 at 9:05:45 am
Thanks!!
