Any tricks to fix over-sharpened video?
Perry Kroll
on Sep 16, 2014 at 10:44:01 pm
I'm working on a project with a ton of mixed media sources, and some clips were shot on a Canon Rebel that unfortunately had sharpening turned up all the way in the shooting profile.
Anyone ever come up with a clever way to at least partially fix this?
Chris Wright
Re: Any tricks to fix over-sharpened video?
on Sep 17, 2014 at 12:54:29 am
find edges, shift alpha as luminescence, levels-alpha white/black. set as alpha matte for fast blur .2. should smooth the black edges.
Perry Kroll
on Sep 17, 2014 at 5:14:41 pm
Works like a charm! Crappy footage now slightly less crappy. I also blurred the matte layer a bit which seemed to work better for my situation.
Daniel Gregory
on Jan 19, 2015 at 9:51:55 am
Is there anybody here that could expand on this? I am having the same problem but the solution that Chris gave doesn't quite go into enough detail for a new guy like me!
Chris Wright
on Jan 19, 2015 at 2:15:19 pm
Here's a template AE cs5.5
8107_silkmasterbluredgesaddtexturecolorgrainaecs5.5.aep.zip
Daniel Gregory
on Jan 19, 2015 at 2:47:38 pm
Thanks for sending that through Chris. Sorry, I'm pretty new to After Effects, is there a simple way to explain how I use one of my video files with your template to try it out.
Chris Wright
on Jan 19, 2015 at 3:14:09 pm
Right click replace image sequence with footage, then controls layer has sliders. The comp is hd so you may need to resize as nessessary
Daniel Gregory
on Jan 20, 2015 at 7:51:16 pm
Thanks Chris!
Harry Fear
on Mar 14, 2018 at 1:09:23 pm
Folks, I'm dealing with a similar problem.
Footage was over-sharpened in-camera on the DJI Osmo. [The cameraman made a mistake.]
I've tried the AE template but all I see is a weird coloring effect and no effect to image sharpness.
I see the edge blur, texture, color, grain, on/off effects applied. But I don't see any real effect on the footage:
with on/off on: https://image.ibb.co/jYp5cx/Screen_Shot_2018_03_14_at_13_01_38.png30.png
with on/off off: https://image.ibb.co/fBFdxx/Screen_Shot_2018_03_14_at_13_01_
original footage: https://image.ibb.co/d2vNPc/Screen_Shot_2018_03_14_at_13_05_57.png
Any ideas?
“find edges, shift alpha as luminescence, levels-alpha white/black. set as alpha matte for fast blur .2. should smooth the black edges.”
I believe your instructions will work, but could you break them down so I can recreate them?
