Wipe effect
Tamas Toth
Wipe effect
on Sep 15, 2014 at 7:34:21 pm
I have a blackboard background and I have white text on it. I'd like to know how I could create a wipe effect? So when the board is full, I'd like to wipe the text off of it.
John Cuevas
Re: Wipe effect
on Sep 15, 2014 at 7:45:32 pm
I've done this by placing a copy of the blackboard above it, open the layer window and using the eraser to "erase" the blackboard, then just animate the "start" or "end" position under the stroke options. In effect you are wiping on the blackboard over your text, but it looks like the text is being erased.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
