Handing Lower Thirds to Video Editor - Frame Rate
nina kumar
on Sep 11, 2014 at 10:17:03 pm
I am creating some Lower third IDs for an awards show. I will be passing off quicktime file to the editor who will be editing them on top of footage clips. He will be rendering out the final video as Pro Res HD 720p/24. What would be the best frame rate to work at in After Effects? Also the best render setting, Pro Res, H.264?
Roland R. Kahlenberg
Re: Handing Lower Thirds to Video Editor - Frame Rate
on Sep 12, 2014 at 9:05:01 am
[nina kumar] " What would be the best frame rate to work at in After Effects? Also the best render setting, Pro Res, H.264"
Your editor should let you know the frame rate requirements since your output framerate should match his.
As for CODEC, again, it's often best to follow what his timeline settings.
HTH
- Roland
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
Walter Soyka
on Sep 12, 2014 at 1:55:18 pm
[Roland R. Kahlenberg] "As for CODEC, again, it's often best to follow what his timeline settings."
Keeping in mind that your titles may require alpha channel support.
Walter Soyka
