Multiply one object to fill composition space?
Jordan Davies
on Sep 11, 2014 at 12:18:38 pm
I've been fighting with this problem for a while.
I have a shape (An X) that I want to pop up slowly at first, then speed up over time
to randomly fill the entire composition space in a regular pattern. Is there a way of
using an expression for this? Or an multiply effect that can be conformed to a grid?
jordan.
Daniel Waldron
Re: Multiply one object to fill composition space?
on Sep 11, 2014 at 4:13:27 pm
Aescripts.com has a layers2grid script that might help. I think they also have some random layer shifting scripts. You could keyframe one X to pop on, then duplicate it however many times you need before applying these scripts. Someone else probably could come up with an expression to do what you need, but I personally would just do it manually.
Jordan Davies
on Sep 12, 2014 at 10:29:32 am
Hey Daniel,
Cool thanks for the help!
Jordan.
