AE Mask Problem
Lewis Lloyd
AE Mask Problem
on Sep 10, 2014 at 3:04:50 pm
Hi there,
I'm quite the rooky in AE - Just trying to do a screen replacement.
I started getting this problem when trying to apply a mask, see the
screenshot - like it's masking more than the actual mask edges.
Anyone have an idea what I'm doing wrong here?
Any help much appreciated, thanks!
Lewis
Doyle Lewis
Re: AE Mask Problem
on Sep 10, 2014 at 3:12:43 pm
what happens if you turn off your corner pin effect?
Doyle Lewis, Assistant Videographer
thinkck.com
Lewis Lloyd
Re: AE Mask Problem
on Sep 10, 2014 at 3:24:08 pm
Hi Doyle, thanks for your reply.
That does make the mask work thanks,
but doesn't that mean it's not tracking any more?
I just want to feather in the edges of my replacement
screen which i've tracked.
thanks
Lewis
Lewis Lloyd
Re: AE Mask Problem
on Sep 10, 2014 at 3:46:44 pm
Roland R. Kahlenberg
Re: AE Mask Problem
on Sep 10, 2014 at 4:06:28 pm
Your insert layer MUST be the same size as the composition where you apply the Corner Pin tracking data.
Place the insert layer into another composition and scale the layer to fit the composition size - the CTRL+ALT+F shortcut key does this. Then nest this composition into your 'final comp'. Then apply your Corner Pin tracking data to this nested comp.
HTH
- Roland
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
Lewis Lloyd
Re: AE Mask Problem
on Sep 10, 2014 at 5:00:56 pm
Thanks a lot for the tips Roland,
that must have been it, because
I scaled down the layer to fit into
the screen.
Thanks everyone!
Lewis
Re: AE Mask Problem
on Sep 10, 2014 at 6:00:53 pm
If you need to blur the edges of the insert layer, apply Effect>Blur and Sharpen>Channel Blur AFTER the Corner Pin. Then tweak the Alpha Blur value to taste.
HTH
- Roland
Lewis Lloyd
Re: AE Mask Problem
on Sep 11, 2014 at 10:39:41 am
awesome!
Re: AE Mask Problem
on Sep 11, 2014 at 7:19:29 pm
WooootS!!!
- Roland
