Simple Text Animation
Lloyd Ernest
on Sep 9, 2014 at 4:25:19 pm
Hi there,
I'm trying to create an animation for text where each character shuffles one to the right, frame by frame - similar to this video
I'm using CS6 and have tried looking everywhere for default animations similar to this - the closest I've found is the character offset animator, but ideally I'm hoping to have the scrolling characters like in the video.
Any help/recommendations would be very much appreciated.
Thanks very much
Lloyd
George Goodman
Re: Simple Text Animation
on Sep 9, 2014 at 6:03:27 pm
You could type out 10 (or so) different text layers (each one frame long) so that each letter was shifted one space to the left, precomp it, then use a loop out expression with time remap.
"|_ (°_0) _|"
Sincerely,
George
http://www.vimeo.com/georgegoodman
http://www.linkedin.com/in/georgefranklingoodman
Lloyd Ernest
on Sep 9, 2014 at 7:29:33 pm
Thanks for your reply! That certainly would be an option, however (annoyingly) I have to make 30+ different words animate on one comp, so ideally looking for something I can copy and paste over the lot.
Cheers anyway
Roland R. Kahlenberg
on Sep 10, 2014 at 3:25:14 am
You can do this with some Expressions code in the Source Text property, coupled with some keyframing/Expression in the Position property. I suggest that you post your Q in the COW's AE Expressions Forum.
Cheers
- Roland
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
