Extendscript syntax for disabling stopwatch on layer property
Rob Coakley
on Sep 5, 2014 at 3:30:52 pm
I cant seem to find the property that will allow disabling the stopwatch or keyframes on a layer property. I found "app.project.item(index).layer(index).propertySpec.isTimeVarying" but it is only read-only.
I am currently working on an extendscript that will supplement clean up of an imported Maya ASCII File.
When a Maya ASCII is imported all properties are keyed on every frame. I would like to disable Time-vary from some of the properties after the file is imported.
Walter Soyka
Re: Extendscript syntax for disabling stopwatch on layer property
on Sep 5, 2014 at 4:20:06 pm
I would use removeKey() iteratively on every keyframe in the property, from the last one to the first.
prop = app.project.item(index).layer(index).propertySpec;
numKeys = prop.numKeys;
for (i=numKeys; i>0; i--) prop.removeKey(i);
Walter Soyka
DR Greenlaw
on Mar 25, 2015 at 7:38:24 pm
This was exactly what I needed to learn today. Thank you!
G.
Greenlaw
Artist/Parter | Little Green Dog - http://www.littlegreendog.com
Senior Digital Artist | Rhythm & Hues Studio - http://www.rhythm
