Flow of circles
Nathan Porter
Flow of circles
on Sep 5, 2014 at 1:45:02 pm
I have been animating circles following a path with the echo effect. I am showing the flow on a hydraulic schematic. I run into trouble when I have multiple lines stopping and starting. It becomes very time consuming keeping them all looking natural and working. Is there maybe a better way of doing this. I have used expressions a little and was wondering if there might be a way to use those. Not sure but would love any feed back. I am including a link of what I have been doing so you can see what I am trying to explain.
https://vimeo.com/105271400
Thanks Nate
Nathan Porter
Roland R. Kahlenberg
Re: Flow of circles
on Sep 5, 2014 at 3:15:54 pm
I've attached a CS6 AEP. The AEP includes example of a Shape Layer that has been used to create animated dots around a path.
The tricks to creating this effect are -
1) Set Line Cap to Round Cap
2) Set Dash Size to 1
3) Add a Gap Property - click on the + button on the right of Dashes to add a Gap Property
4) Use the Offset property to animate the dots
7946_animateddotsshapelayer.aep.zip
HTH
- Roland
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
Nathan Porter
Re: Flow of circles
on Sep 5, 2014 at 5:06:09 pm
Thanks Roland I will give that a shot it looks much easier.
Nathan Porter
