I have a question
Sato Teruaki
I have a question
on Sep 5, 2014 at 12:06:22 pm
Hi there.
I have a question.
Do you know that you are using what effect this video.
https://vimeo.com/78349868
Roland R. Kahlenberg
Re: I have a question
on Sep 6, 2014 at 1:06:52 am
There are lots of effects in the video. You should specify the timeframe where the effect occurs and describe the effect; just in case there are more than one effect at play, at the specified timeframe.
Cheers
- Roland
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
Sato Teruaki
on Sep 6, 2014 at 1:48:57 am
Thanks a lot!
Ill try :)
Sato Teruaki
on Sep 6, 2014 at 2:01:41 am
I want to know what kind of effect about riangle kaleido.
time is 0:22~0:23.
sorry my english is not good.
on Sep 6, 2014 at 11:59:00 pm
I'm not certain if it's a standard transition effect found in a 3rd party effects/plugin. If I were to create it manually, then masks will be used to cut up the video. Position, Rotation and Scale transformations will then be used to move the masked areas.
HTH
- Roland
Sato Teruaki
on Sep 7, 2014 at 1:30:21 am
Thanks reply!
I will try using mask with After Effects.
