Preview render stops when I browse net or anything aside from AE
Gina Miller
on Sep 4, 2014 at 12:03:24 am
When I am previewing a render, not the final, if it takes some time I want to go to my browser or go to another folder and do something else while I wait but then the prerender stops? Is there a way that I can change this so that it will still pre render and I can do other things at the same time? Thank you! Gina
Todd Kopriva
Re: Preview render stops when I browse net or anything aside from AE
on Sep 4, 2014 at 12:21:31 am
Show a screenshot of your Memory & Multiprocessing preference settings.
After Effects team blog
Gina Miller
on Sep 4, 2014 at 1:31:31 am
Here it is:
Roland R. Kahlenberg
on Sep 4, 2014 at 1:15:22 am
I believe that you have invoked a preview via the SPACEBAR. Such a preview will stop when AE is no longer the active application. Such a preview also does not include audio.
Instead, you should invoke a RAM Preview, which is done by hitting the ZERO key on the numeric keypad.
HTH
- Roland
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
Gina Miller
on Sep 4, 2014 at 1:35:05 am
Thanks Roland thats it, but RAM preview doesn't work if I hit zero for some reason I have to click the arrow?
Also - that will make it so I hear audio every time right?
G
on Sep 4, 2014 at 1:40:45 am
Hi Gina, it's the 0 key on the numeric keypad that starts a RAM Preview - NOT the 0 on the main keyboard.
You will hear audio provided the disable audio button in the Preview Panel is not switched on.
HTH
- Roland
Gina Miller
on Sep 4, 2014 at 1:51:27 am
Oh shoot, I don't have one : ( I've got the small mac keyboard because my hands are so small. It doesn't have the numeric.
on Sep 4, 2014 at 1:58:16 am
There are alternative shortcut keys for AE users without a Numeric Keypad. Take a look-see here - http://blogs.adobe.com/aftereffects/2010/04/added-alternative-keyboard-sho....
Of course, the RAM Preview button in the Preview Panel is also a good alternative.
Cheers
- Roland
Gina Miller
on Sep 4, 2014 at 2:04:00 am
Cool. Thanks! G
Dave LaRonde
on Sep 4, 2014 at 6:05:08 pm
You may not be patient enough. When you hit zero on the numeric keypad, AE begins to BUILD a RAM Preview, and it keeps doing so until all the RAM available to it is filled. Then it plays it back in as close to real time as it can.
If you hit zero and expect instantaneous results, you won't get them. AE isn't an editing application where you hit the space bar and it plays -- it does different things, works in different ways and you must get used to the way it works.
Dave LaRonde
Promotion Producer
