Squeezed image when linking from Premiere CC
Jake Rose
on Aug 29, 2014 at 3:41:33 pm
This is a new issue for me:
(Original footage is HD, 1080p, recorded into a BlackMagic Hyper Deck Studio Pro in QT 422.)
When I right-click on footage in Premiere CC to "Replace with AE Composition," the image appears in the new AE comp squeezed into a square (4:3) window. However, back in Premiere, the footage looks fine. I could continue working and just deal with the squeezed perspective in AE, but it is troubling to look at. I've tried playing with some of the composition settings and I can't seem to fix the issue.
If I play with the squeezed footage in AE, like further squeezing or stretching the image, than it will appear distorted in Premiere.
Walter Soyka
Re: Squeezed image when linking from Premiere CC
on Aug 29, 2014 at 6:02:37 pm
What are the comp settings in Ae?
Does toggling the Pixel Aspect Ratio Correction button [link] on the viewer help you?
Walter Soyka
Jake Rose
on Aug 29, 2014 at 8:11:57 pm
Mr. Soyka you are the man!
Hitting the Pixel Aspect Ratio Correction button fixed the problem!
