adjusting alignment of a compososition
Amelie Lim
on Aug 28, 2014 at 7:12:00 am
Good day! =)
I have a simple question about AE.
How do I move the composition to the left as shown in the image below?
http://i61.tinypic.com/v42az8.jpg
I can't find the alignment settings in the composition. I can only adjust the size.
Your response is appreciated.
Tudor "Ted" Jelescu
Re: adjusting alignment of a compososition
on Aug 28, 2014 at 1:07:59 pm
If you're referring to moving the position of your comp (frame) in the comp panel, then all you need is to press and hold the space bar while right click-ing and moving your mouse in the Comp panel. This will move your comp frame around.
Tudor "Ted" Jelescu
Senior VFX Artist
Dave LaRonde
on Aug 28, 2014 at 6:39:48 pm
I just eyeball the position for something like that. It usually works just fine, and it takes less than a minute. A lot less.
Dave LaRonde
Promotion Producer
Amelie Lim
on Sep 1, 2014 at 5:17:29 am
eyeball the position? I'm sorry but could you elaborate more on how to go about it?
