Masking multiple Particular solid layer
Duca Simone Luchini
on Aug 27, 2014 at 8:53:56 am
Hallo everybody,
I meet a problem using a multiple 3d layer composited on a multiple fog banks particular (sandwich tech).
Having two 3d layers I must use a multiple particular layers, tree exactly, to use them between the two different 3d layer. It works pretty good.
But now I need to mask the tree particular fog bank to cut out some particles to match perspective scene orientation (see red mask).
I didn't find any solution about it...
First, mask doesn't work on a particular solid layer. Second, If I pre-compose the particular solid layer, it looses perspective set up (please, see attachments) with every set up...
In this case I have tree particular solid, as well...
So, may you suggest a solution to mask fog (as shown with red lines mask in picture 2)?
Many thanks for a reply!
Duca Simone Luchini
Re: Masking multiple Particular solid layer
on Aug 28, 2014 at 6:35:43 am
Anyone has no ideas? Suggestions?
© 2018 All Rights Reserved
