After Effects Renders looking pixelated in FinalCut
Tracy Kim
on Aug 25, 2014 at 3:08:58 pm
Hi Everyone, I have a question about my After Effects renders looking pixelated when brought up in Final Cut.
I am rendering a comp with Alpha using these setting : 1920x1080 29.97 square pixel ..codec:Animation
Editor's Final Cut settings are: 1920x1080 29.97 frame rate square pixel ..no field dominance ..export codec is apple prores 422
Could any please tell which other codec can I use that will export alpha channels and will not make renders look pixelated in Final Cut?
Hamdani Milas
Re: After Effects Renders looking pixelated in FinalCut
on Aug 25, 2014 at 6:36:31 pm
I have also come across this problem. Fixed it by calling up Item Properties on the AE render after importing into FCP and checking the field dominance, in my case it said Upper (Odd) even the the render was 422 progressive. Right click on the Field Dominance and change it to None, then try bringing the clip into your edit sequence. Pixelated look should be gone. Don't ask me why or how! As far as I can see it might be the way FCP is flagging and interpreting the file rather than being an issue with the AE render. Hope this helps!
H Milas
Independent producer, director, cinematographer, writer, editor
Milas Film Productions, Hong Kong
http://www.milasfilm.com
Mac Pro 3,1, NVidia Geforce GTX285, 16GB RAM, 480GB Mercury Extreme Pro 6G SSD system drive, OSX Snow Leopard 10.6.8, Caldigit VR 4TB e-SATA RAID, FCP 7.0.3, CS6 Production Premium Suite
Tracy Kim
on Aug 25, 2014 at 6:40:35 pm
Thanks. I'll give it a try.
