move keyframes between two key frames
Joe Mole
on Aug 22, 2014 at 7:56:17 pm
A long time ago I did a project where I had tons of keyframes between two keyframes. The keyframes in-between were smaller dots on the timeline and if I grabbed one of the end keyframes the keyframes in-between would move sort of like a rubber band. I'm trying to do this again in order to control the animation time between the start and end of two keyframes. Does anyone know what I'm talking about and how to do this? Thanks a ton!
Kevin Camp
Re: move keyframes between two key frames
on Aug 22, 2014 at 8:03:56 pm
you can simply select all the keyframes (or a group of them) and then option-drag (or alt-drag) the first or last keyframe and the select keys will 'redistribute' accordingly.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Todd Kopriva
on Aug 22, 2014 at 8:10:12 pm
Kevin is correct.
Regarding what you were seeing in your previous project: roving keyframes.
After Effects team blog
