AE tutorials for some effects
Rahul Sheth
on Aug 21, 2014 at 8:48:33 pm
Guys I am new for this forum as well for AE. So please guide me as I needed to learn specific effects as I have to make some. Below are some links for which I needed your help.
1)
- Here there are three things, I want to know.
i)How to create that circular effects which around a logo in this video.
ii)How to create that background which have white balls going up and curtain effects
iii)How to create an effects like a light which passes through that logo.
2)
- Here how to create effects for falling rose petals
- Also if I have to some photos on petals, how can I do it.
Guys if anyone have video of how to make such effects please do tell. I have to make it for sister's wedding function in some presentation.
Doyle Lewis
Re: AE tutorials for some effects
on Aug 22, 2014 at 1:02:40 pm
For both effects you are really going to have to learn Particle simulators. Here are the ones I suggest with a link following them that is a tutorial of how they work.
Trapcode Form:
http://www.redgiant.com/videos/getting-started/item/378/
Trapcode particular:
http://www.redgiant.com/videos/getting-started/item/346/
http://www.redgiant.com/videos/getting-started/item/362/
Element 3D
http://www.videocopilot.net/help/element/tutorial/basic/3d_replicator/
Particular might work for both effects so I have attached two links to it. For the rose petal effect though element 3D might work better, but that's only if you can get your hands on a rose pedal 3d model.
Hope that helps. It will require you to buy some software but those are the only ways I know how to do it. You might be able to do the first effect with cc particle world which is a bundled effect in After Effects already, but it would be more difficult than using trapcode.
Doyle Lewis, Assistant Videographer
thinkck.com
Rahul Sheth
on Aug 22, 2014 at 6:57:42 pm
Appreciate your help.
John Cuevas
on Aug 26, 2014 at 11:55:46 am
You may want to check out these tutorials also they use the effects that come with AE:
Stroke Effect
Sparks Effect
3D Lines
Particle Explosion
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
