Line between 2D null and 3D layer?
Jiri Fiala
on Aug 19, 2014 at 7:59:22 pm
Hi!
I've got a scene tracked with the built-in 3D tracker camera. I also have a 2D null that tracks the movement of an object that I tracked in Mocha AE.
Now, I need to draw a line between the 2D-tracked null and a 3D layer that moves with the camera (=it sticks to the footage).
I tried Motion Boutique's ConnectLayers script but it doesn't connect 2D and 3D layers properly (only two 2D or two 3D layers).
Can anyone help? Thanks!
Jiri Fiala
Re: Line between 2D null and 3D layer?
on Aug 19, 2014 at 8:06:41 pm
When I parent the 2D null to the camera, I get proper connection, but the anchor point of the null is off (see the picture - the line that now ends in the middle of the blue pre comp should be ending on the null)
Kevin Snyder
on Aug 19, 2014 at 8:18:05 pm
You need to convert your 3d point to 2d coordinates in order for it to work. Hopefully this will help.
http://provideocoalition.com/pvcexclusive/story/expression_shorts_-_attach_...
Jiri Fiala
on Aug 19, 2014 at 8:30:22 pm
Thanks, but that knocks the null way off its original position.
Kevin Snyder
on Aug 19, 2014 at 8:39:37 pm
Did you make a new 2d null and reference the 3d layer you want the line to go to?
Jiri Fiala
on Aug 19, 2014 at 8:43:13 pm
Oh! I was applying the expression to the original tracked null, which is obviously wrong.
It works! Thank you so much!
Kevin Snyder
on Aug 19, 2014 at 11:34:18 pm
Glad to hear that you got it to work!
