Loop a write-on effect
TImi Boose
on Aug 19, 2014 at 12:03:09 am
I am creating a simple drawing and animating the sun's rays bouncing off a window to show how a certain type of glass in a window works. I animated the sun's rays with the write-on effect and it works good but only goes 1 time. I want to loop the write-on effect so that it will happen repeatedly.
I tried adding the expression loopOut("cycle,0) .....onto the brush position control in the write-on effect but it still only goes one time....
Declan Smith
Re: Loop a write-on effect
on Aug 19, 2014 at 12:54:00 am
You could try precomposing the brush layer and adjust it's comp length needed to complete one cycle and then on the precomped layer in the main comp, add time-remap and then loopOut on that and drag the length to the end.
Declan Smith
http://www.madpanic.tv
After Effects CS6/ FCS3 / Canon XLH1 / Canon 7D / Reason / Cubase
"it's either binary or it's not"
