Is it possible to create composition with FPS less than 1?
Ivan Balalayka
on Aug 17, 2014 at 11:56:47 am
Hi, I'm using AE CC 2014 and making gif with still images in it, and want it have small size. I need change image every 2 seconds, so basically I need 0.5 FPS in composition, but I can't do this in AE composition settings, when I set it to 0.5 (also tried 0,5) after pressing OK it's going back to 1 FPS. Any ideas how to perform this?
Joseph W. Bourke
Re: Is it possible to create composition with FPS less than 1?
on Aug 17, 2014 at 1:54:43 pm
Maybe if you increase the frame rate of the composition, you will achieve what you want. By doing 60fps, you should get a frame every half second. Does that make sense?
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com
Ivan Balalayka
on Aug 17, 2014 at 6:26:58 pm
Hmm, no. I will get 30 frames on half second, now for 2 second of still non-changable image I have actually 2 same images in rendered sequence, i.e. 1 frame per second, but I need 0.5 frame per second, i.e. 1 frame per 2 seconds.
Walter Soyka
on Aug 18, 2014 at 12:05:20 am
[Ivan Balalayka] "I need change image every 2 seconds, so basically I need 0.5 FPS in composition, but I can't do this in AE composition settings, when I set it to 0.5 (also tried 0,5) after pressing OK it's going back to 1 FPS. Any ideas how to perform this?"
The minimum frame rate in Ae is 1.0 frames per second.
Walter Soyka
