Export coorinates of 3D layer
Boris Rozhkovsky
on Aug 15, 2014 at 8:19:27 am
Hello
A have 3D Square layer moving/ rotating over the scene.
How can i export it`s corners absolute coords on the screen, using script? This Layer is not a Shape or Mask, it is regular layer with photo.
Walter Soyka
Re: Export coorinates of 3D layer
on Aug 15, 2014 at 11:38:29 am
You can actually do this pretty easily with expressions.
Create 4 2D nulls, one for each corner, and apply one of these expressions to each:
// top right corner
L = thisComp.layer("3D Layer");
L.toComp([0,0]);
// top left corner
L.toComp([L.width,0]);
// bottom right corner
L.toComp([L.width,L.height]);
// bottom left corner
L.toComp([0,L.height]);
Select the position property of each of these nulls, and from the Animation menu, choose Keyframe Assistant > Convert expressions to keyframes.
Select one of the null's position properties, then copy, then paste into Excel. You'll get keyframe data for that point. Repeat for each of the nulls.
Walter Soyka
Boris Rozhkovsky
on Aug 15, 2014 at 11:53:15 am
Ok thank you very much, what if i want to bind mask`s 4 verticles to 4 corners of layer?
Walter Soyka
on Aug 15, 2014 at 12:06:49 pm
[Boris Rozhkovsky] "Ok thank you very much, what if i want to bind mask`s 4 verticles to 4 corners of layer?"
http://aescripts.com/bao-mask-avenger/
Walter Soyka
